  • Replies 306
Posted Images
sent application and paid money..
this time im coming with gate wide open....watch out Roman round 2 is on!!!!
ha ha, ITS ON LIKE DONKEY KONG
i'm gona bring spare tires, i'm near the tread wear indicators if i'm still rolling on 4stud
i may be rocking the R33 brakes and 5stud by then, if 5 stud i'll be stuck with R33 stockies :(
new wheels should arrive mid Nov
i may be rocking the R33 brakes and 5stud by then, if 5 stud i'll be stuck with R33 stockies :D
i will be bringing stockies just incase there is free time on the skidpan in the arvo :(
Howdy Guyz,
Hope everyone is well; I've been offline for a while working my azz off!
Looking forward to my 2nd DECA event as the first one in May was a hoot and I've developed some type of crazy motorkhana withdrawal symptom after the first dose! Is there such thing as a tarmac challenge red cone chemical inbalance? :(
FYI: DECA dollars already deposited and will be emailing my entry form tomorrow after I locate my CAMS passport thats floating around home somewhere!
Cheers
Ben
form sent via e-mail, and money sent as well :( . time to get my new tyres and brake pads and shift kit installed now.
shift kits are very worth while... TJ has had his trans built by RVO, i have had maintenance done by them, seem like a good bunch. My knox autos shift kit is great, but dont rate them as a workshop
yea ill be getting 4 spare tyres this time, ima use the same rears and finish them off and run re55 on the front....without ABS....
is 180sx ABS any good anyway?
AASA form:
Club_Racing_License_Application.pdf
i forgot to attach the other form so i sent another e-mail and this time attached both lol sorry about that.
yeah alot of people say the shift kit is worthwhile i also got a bigger trans cooler to go with it and some new defi gauges lol. ive been preparing for a while, i just got to get it all put on now. ive herd good things about RVO but they are on the other side of melbourne. luckily where i get my car worked on just around the corner is an auto tran shop that has fitted a few of these which is perfect.
entry list updated.
there are 2 names missing at the moment. this is because when they are converted to email the attachment is lost. i will have them tommorow so do not worry if you are not on there yet. (those sent between 9-930 wed morning)
entry list updated.
My entry went in Tuesday night.. let me know if you didnt get it Leon sent it..
sent the both in on the same fax, if not i have them in my office so i can re-send them you need...
money transfered and forms faxed. will get licence on the day
ppl. be prepared to watch a total noob make a fool of himself :dry:
There's generally lots of competition for that title, especially me this time. I'm coming with my daily, a CE Lancer with a few performance, but no handling mods.
I will be faxing my entry today.
ill take it this time hahahaha. never done anything like this and still not 100% used tot he power. oh well it will be fun though
Danes bringing the better car!! haha
Very funny Ryan..
Haha I knew you'd put something like that there Ryan...
Well I can't just throw RE55's with tread in the bin, even if they are 5 years old. They will get a DECA farewell, which is fitting as DECA was the place that ruined them in the first place! :mrt:
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
