We have had a couple of people pull out so Entry list is updated.
Tom Giordano and Stevn Trajkovski are in.
Reserves
1 Daniel Robson AE86 RWD
If you missed out you can still get your name onto the reserve list. people pull out the most in the last week.
  • Replies 306
Posted Images
Reserves
When is the latest you can pull out and still get a refund?
Chris McColgan is have medical issues which he may not have recovered from in time.
LOL that sounds like they just feed everyone onto the track until the thing is full? A bit like dodgem cars without the hitting and the clanging?
On another note I got my car back from the panel shop today so I could have made it to this afterall had I been in quick enough.
Nah sounds like the nurburgring.
kinda scarey what they let out there!
After another engine failure in the Evo at Winton Saturday I'm left with only one car, so I have to pull out damn it.
Good for the reserves tho'
Have a great day all, as always, and see you at the first DECA in 2010.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
