  • Replies 14.2k
Not sure how many soccer fans are on this board but it was nice to watch Adelaide United win the first game of the Asian Champions League last night.
Despite finishing bottom of the A-League they won their last two games and now have 3 wins in a row to build some momentum to take OS. The team looks better too with the new signings.
GO REDS!
well boys and girls i have just made my lunch it consists of a ceaser salad mix from the super market an avocado cherry tomartos mushrooms and a fresh roast chicken all mixed together for a drink its apple and mango juice made by mountain fresh and for a snck passionfruit yoghurt from the yoghurt shop yuumm
yer Ive got a chicken caesar here to eat today too.
cheap food for a day
paid for the missus to have a holiday. so I thought bugger it, i need a power-fc
bought one from ebay for $690 incl hand controller for the rb26dett, including a tune from JUN (stage 1).
thats the last thing i needed for the r32 sedan.
just got to chop the $1.25 cage up to suit, then tune at boostwerks on 7th april.
must get to it and fit the speedo cable, meh sore too sore :huh: need a hoist
Be careful the tune will be set for 100RON.
yes but did you buy it made or did you make it
your so lovley you paid for her to have a holiday
thats cheap for a power fci remember about 3 years ago when pfc's were not around and i was working at auto barn sitting on ebay trying to buy one for a customer at 1500
I had an et turbo .
Between blowing gear boxes and turbos and every other f**king thing on the car up, they arent bad.
Money pits. Non turbo might be the go tho?
http://www.pulsarparts.com.au/Default.asp
Honestly man. I spent alot more on that ET turbo than I have on my 34.
Shit goes wrong with them. cursed.
Old turbo cars = big trouble.
I went through 2 gearboxes, which aren't cheap.
2 turbos, which also weren't cheap at the time.
went through regency about 3 times with it.
Shit falls apart on them.
Cursed I tell you.
couple pics
Matty got another tow for you my friend.....
PM sent
GO REDS!
that was an own goal wasnt it.....but i think Lachie claimed it....good to see them off to a good start.....just a pity that Arsenal lost their game to porto.....good thing it was an away game for us.....
Well i had mongolian lamb with fried rice......very very good from a little chinese place and the price for all under $12 gotta love it...and for the drink was a iced tea yumm....followed by a cancer stick :huh:
I need a half decent daily lol :huh:
then don't buy a ET, they fall apart as steve said
buy a R31 , cheap, use the RB30 someday, parts from wreckers easy to find, etc
mine has over 500,000k on a unopened engine, head seeps a bit of coolant but still idles better then the R34...lol
I need a half decent daily lol :O
might be selling my r31 s3 exe. 1989, first regod in 1990, white very very good condition for the age.
brand new: xtreme hd clutch, radiator, water pump/pulley, belts, full exhaust, manual conversion (second hand obviously) and few more brand new parts. have receipts for over 3K in just brand new parts.
+ got full pioneer speakers all round, jvd cd/mp3 deck n more shiz.
also at the right price will throw in a brand new "nismo" pack lol including: brand new nismo steering wheel, gearknob, pedals, bucket seat and seat covers ;)
:D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
