I drove to Bowral for the w/end - saw so many stinking skylines but only 1 recognised my car and flashed/waved and that was a S1 R33 Gtst w/ GTR front bar, plates FLYXXX (X = something i cant remember)
Saw 2NTYSU in bowral, nice white S2 with white rims, another white S2, a wine red S1 on the way home on M5... saw tonnes more, cant remember them all. The car scene in Bowral is pretty impressive.
Christian
Christian
woohoo somebody finally spotted me!
its a trust copy front bar btw :cheers:
I saw somthing... It looked like a series 3 R31 rear end had badges on the back that said 'turbo' and 'Passage'. It was a 4 door but seemed not to have the middle pillars (is that the 'B' pillar?)
It was at Coogee on Saturday morning or whatever time I got there for breakfast.
Saw a nice lime green 32 coming out of Panthers around 2am Monday morning, and 1pm Monday a dark blue 32 (MIDN9T?) going up the M4 at Emu Plains.. heaps of others over the wknd as per usual these days..
Spotted R33 series 1, 2 tone 4 door on Princess hwy out the front of Tynan motors.
Plates: MIZ 25T with green p's
CAR: Has 18's, backs are dished and aftermarket BOV & Exhaust...
Was a very sleek 4 door....
Oh, was also missing a passenger side mirror... :cheers:
I spotted this car on Sat Night in Cronulla...... Remember because of the hanging mirror!!!!
Jono - what power you making now ?? Ummm if my memory is right (too many beers) - Ahhhh I don't even remember ----->
60rwkw is a great gain - NO A TOPS GAIN!
Well done mate :)
Now making 248rwkw's, good gain up from 188. Added Power FC, Cam gears and 2 pounds of boost (12 up to 14) :)
hahaha... well when you subscribe to a thread, you tend to keep checking when you get replies :( also got that thread via e-mail as well! ;)
also spotted a darkish 33 last night... around 11ish... thanks for the games from the m4 down silverwater rd :)
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
