SPOTTED: on old pac hwy a white r33 boosting up the hill ... gave each other a wave as i was going the other way with a coupla frenz
Finally been spotted!
We ended up in Wollombi for a bite to eat then headed back to Sydney. We saw emergency vehicles fly through Wollombi later discovering that we had missed a bike accident by literally minutes on the way there. It was around the bends after the observatory.
See you around
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
