I was wondering if you were from SAU, 'cos I didn't spot any stickers on the car (kinda hard when you're travelling down Oxford anyway, what with all the suicidal pedestrians and fking taxis stopping whenever and where-ever they want to).
Yeah, the big Stagea ain't too bad, hey?  Was actually expecting to be left behind by you, considering the MASSIVE weight difference.  Apart from the exhaust (I took the silencer out tonight to see if it improves fuel economy, by the way, so hopefully it sounds a bit different too) and the manual conversion done by the previous owner (R-32 GT-R box and six-puck clutch), it's stock as a rock - for now...  Different time, different place (away from the street, or at least that much traffic), maybe the resukts will be different again.
Cheers,
Nick T. ;)
Oxford st makes a very interesting driving experience thats for sure......
I was just cruisn along with a bit of a g up rev.... wasnt going hard at all i leave that to the track as i value my licence and way too many coppers... i need one of those sau stickers :cheers:
I've spotted a grey R32 around North Sydney a couple of times number plate HCR*** with a SAU sticker on it.  Anyone know who that is?
spotted him too going along m5? damn nice sound from that car.. big ass turbo and exhaust :(:D:D
spotted so many skylines on the weekends... one going sideways near bondi jct today...
got a nod from a 32 in the city.....
saw a few more 33s..... damn theres alot around :D
Spotted HOTTEE a few times on Saturday night while cruising the city. Also spotted MARSS5 on George St.
Hahaha! I saw HOTTEE too... pink dash... oh well.. didn't see ya man..too busy dodging taxis :lol:
Spotted some sexy chick in a r33 in seven hills:D
dark skin dark hair dark car :D
and a black r33 on epping rd.. and a white r34 in seven hills.
oh.. and spotted Mass.. again.. outside his house.. *beep beep*
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
