yup pritty sure it was u, unless some1 stole ur car and had a face mask on that looked like u :P  it was a tuesday around 6:30pm
lol!!!
I'll keep an eye out for ya next week!!!
spotted a million lines this weekend..most importantly the burgundy 33 on the pacific highway at hornsby at 2.45am :wavey: and the blue 32 with white wheels turning on to the pacific highway at berowra 3am :wavey:.. bloody nice car!
at around 230pm today (sunday) i spotted what looked like a pearl white Autech 260rs Stagea with r34gtr rims (or could have been a stock normal stagea :P ) and an black r34gtt both coming back towards sydney through the national park.
then on moore park road i saw a purple r33 gts-t with gtr bits, big rims, loud exhaust, bodyform sticker and nasty clutch by the look of it at about 530pm coming towards the city.
I spotted dinzlr and a bunch of other 'lines cruising down king georges/ryde/mona vale rd.
I feel I need to paint myself yellow, and dance naked in the street singing 'can you spot me' to the tune of 'can you feel it' before anybody will give me a sideways glance... :D
spotted a silver s15 this morning on epping rd :D car looked stock with nice rims... also had a mean sounding exhaust... plates - GRINER... hehehe.. i got a grin so the plates were well suited :D
also spotted what i thought was a skyline on epping rd near the m2... saw it from a distance and thought... that looks like a rexy.... nah.. must be a 4 door sky.... caught up... guess what!!! it was a REXY!!!!!! with round skyline light!!
OMGWTFBBQ
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
