Spotted a fair few skylines this arvo, black R33 GTR (RED39*) and silver R33 gtst (DRE33A) on hume hwy, and another silver r33 gtst followed me off the m5 at moorebank rd
Dammit why don't i ever get spotted on the m5.. im on there at least twice a dar >.<
i sometimes see a silver r32 in the north shore area plates MI-32-SS i dont know if its anyone from here, i also see in my area another r32 with a big sticker along the sides sayin NOTORIOS or something like that lol :happy:
Spotted a Silver R33 with carbon bonnet near Palm Beach on Saturday AM
As well as 2GU UP (I think??) coming down the hill at Pymble on Pacific hwy in the afternoon.
Oh, and got a wave from both :starwars:
Edited by Morgs
yep that was me on the way back from central coast show and shine :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
