You were on the way home I think when I spotted you :D
I was in the peak hour slog home in the daily, the GTR dosen't really like that style of driving (Well, its not economical.. lol)
Cheers!
Was going to Dick Smith on Gore Hill trying to source some back light globes for the climate control buttons, they just cant seem to get the right ones in stock anywhere.
What where you driving? I don't recall any skylines when i was on pac hwy.
SNG.
spotted a poor silver r33 on james ruse drive.. it was involved in a huge accident.. it looked like the whole front end was smashed in.. poor baby :)
also spotted mass fluttering past me... thomas doing a burnout and getting glared at... and ms doing an awesome launch!!!! :D
spotted a poor silver r33 on james ruse drive.. it was involved in a huge accident.. it looked like the whole front end was smashed in.. poor baby :(
:mad:
while.. at.. the.. drags.. yeh thats it.. the drags.. :D
:D
LOL Hey Mass :) Thought it would've been someone I knew :)
Here we go again, Friday night spot SATANIC game - winner this week is Mass, still nowhere close to Lingering who seems to spot me everywhere!
Spotted a few Skylines lastnight around West Pennant Hills.
R32 GTR. - black (no idea about plates)
R33 GTST - white (no idea about plates)
R33 GTST - silver (A??-??? black and white plates)
Spotted a black R32 on the Freeway with green P plates. Big Trust stickers on the front. Plates started with A.
Gave a wave, tint was too black to see if we got one back.
in the last 30 minutes
spotted silver 32 broken down on james ruse drive, I took the exit just before I saw it further up.
white r34 in west ryde
black 32 windsor rd heading towards paramatta
spotted RRR033 again this afternoon on Lower Pittwater Rd in Hunters Hill
also JR34GT yellow R34 GTT with the Nissan Aero kit on Lane Cove Rd near the Comenarra Parkway
Fri arvo?
Spotted by SW20 again? You must be too stealthy!
Not long after that I spotted a 4 skyline convoy (had one black 34GTT) and another trailing 34GTT with P plates going west on victoria rd between powerplay and the gladesville bridge. Someone honked as they pass me but i was stuck behind a Tourak tractor and didn't react fast enough after seeing the first skyline! I pressed my horn late too but it didn't work. AAnyone know where to get a spare horn button? Mine's smashed mine to bits honking someone.
T
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
