lol stealth mode
I think I spotted primordial on Castle Hill Road just then.
White R33 series 2 (series 2 front bar) with GTR wing and white number plate starting with 'A'
Primordial has a GTR 400r type front bar.... Number plate starts with E and sounds like Exhaust.
What he said^ :yes:
I spotted d00dz at Northern Beaches Performance yesterday getting his mis-firing problem sorted :cheers:
The turd goes good once more :yes:
i foresee you'll also be spotting me at NBP very shortly aswell!
good chance you'll also be spotting me there as I got a job at Frenchs Forrest, and the car will need some stuff done to it :D
lol stealth mode
Would of been me... 18" CR Cais??
Just finished a movie at castle towers....
Spotted a white R33 4 door cruising down wicks road yesterday
Silver R33 GTST S2 turning right onto Ryde road from Victoria Road. Gave hime a flash (mmm, with lights). Got one back.
Spot a grey 32 GTR parked on help street everyday. Sweet ride dude.
Saw a r34 today near Forestway - didn't look too healthy minus the rear quarter panel, the 2 tow trucks, the s15, some family cars and the fuzzy muff.
Looked like a d'oh.
Yeah that was me, Silver/Grey R34GT-T 4 Door right?
I was stationary in merging traffic and some silly bitch in a van nailed me straight up the arse at full speed, the whole back window completely smashed through the entire car on impact, and my chassis also damaged. Looks like at least 15K worth!
She hit me so hard the roof of her van buckled.
The S15 had nothing to do with it, that was the old man, who came to give me a lift home.
FARKN SPEWIN
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
