spotted a really cute chick in a white 33 this morning.. on viccy rd, just after gladesville bridge... she was pulled onto the footpath.. hope nothing was wrong!!! got a massive grin and a wave back!! yay! :ermm::cheers:
I saw that car as well on my way to work. Was contemplating pulling over to help but I was in a rush. Didn't see the owner.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
