DIF that would have been the one I fitted an RB25 to a few weeks back. chrome 19's on it too??
Nope, I couldnt tell whether it was gtst or gtr it had the guards to be gtr because the wheels where so tiny, but it didn't sound like a gtr..
shit... i saw, shaolin at Maccas on friday... im pretty sure i saw your car on a dyno about a year or more ago...
met maz in his 34, plates are MAZ 34T i believe... told him to join up ;)
and i think there were a couple others there too, but i forget...
also saw veedka at a party on saturday... he wasn't in his trampoline car though...
hell yeah! spotted.. was yrs a 4 door??? cos i saw one when i was waiting at the lights
also spotted teh Sash on Oxford st
Had a work function at "Slide" (the gay bar, not the gay turbomaker)
once the doors opened to the public, I was outta there quicksmart
didn't see you there... Did you havea gig somewheres?
spotted an awesome R34GTR V-spec, bayside blue, awesome sounding exhaust, AWR45L followed him for a while and gave a wave, but seemed to stuck up himself in his awesome car....i was happy to just look though...
yep! ... This one
spotted a silver r33 gtst with plates BBZ-00M this morning at taren point
and just now saw a black r32 plates AL - ssumfin with an SAU sticker on the back window, turning from forest rd to king georges rd, and a yellow r33 aswell, looked like an 93 model
WOO
spotted the same car near castle hill towers, just turning on to showground, i gave a wave, yeah it sounded awesome
Spotted goldzilla yesterday at about 430pm turning on2 the cumbo highway gave a wave and got 1 back. :P noiceeeee mate
Ahh, sweet. I wasn't sure if you were on the forums or not, but now I know.
