Hahaha.....maybe...if they have an engine :)
Quiet you! :)
Spotted a MINT looking silver R32 GTR heading south on King georges rd around 3pm today
Spotted a gunmetal R32 GTR with R34 rims earlier
Spotted a white R33 GTST near the end of henry lawson drive and followed him till my turnoff on princes highway - it looked pretty low
thats because it was wet Greg ;)
that may be so but it was still the best i have seen on the streets. . . . . ever :)
I had to shake his hand. turns out the car is sponsored but still was fun to watch and i didn't have to pay for entry
Drove into Sydney yesterday to pick up my spoiler and was pretty dam impressed, 20mins out of Sydney on Hume Hwy spotted a blue 34 GTR and then a half hour later a black 34 GTR, 33 GTR and 34 GTT all on Cumberland Hwy.
Edited by Baconer
Spotted a few today;
R34 4door "4RACE" or something like that at cronulla
R32 GTST silver "AJA" (forgot the rest) on kingsway
R33 gtst going through the s bends at tom ugly's bridge.......
R33 GTST with ACT rego in sutherland - gee, wonder who that was?!
R33 blue 4door with white rims in menai
R33 gtst maroon with impuls in menai
spotted a stagea ( i think it was yesterday), white, looks clean as - plates "STAGEA"
There was more but yeah, short memory :thumbsup:
Spotted a black R32 on princes highway around sylvania heights heading north around 730 or so tonight
Also a very nice soundng R32 GTR at cronulla picking up thia food for dinner. Well, the driver was getting the food, not the car ;)
Also a very nice soundng R32 GTR at cronulla picking up thia food for dinner. Well, the driver was getting the food, not the car :D
Is that the one near the station, If so you see the Eggs sitting in the sun all day from the station YUK
Spotted a flouro yellow 31 going around Mt Panorama yesterday :D:wave:
There's one always parked up there that the guy must work there somewhere. Grey - Plates THR-32* or something along the lines of..
Edited by Yidz
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
