Spotted white 33 GTS (possibly GTST.. badge looked blue) on Old Windsor Road around 6:30pm tonight. Plates: LAMB0S
If you're on here, I was in the Corolla that you were following some of the way from the Cumberland Hwy, and then booted past you later on towards Seven Hills more.
Spotted moooooooooooooooooonddaaaaaaaaa..
well Mona spotted me and then beeped her horn like a crazy person .. lol
hehehe.. what about the flashing lights :whistling:
caine was on the phone telling me off for excessive beeping.. oops.. was a lil excited! :thumbsup:
Spotted white 32 with carbon bonnet in towers plates grr something something something
Spotted x2
Right after some c*** copper pulled me over in the carpark thinking I was tearing round the lot, when it was the bloody commodore coming down the ramp.
just spotted a midnight purple 33 gtst with a gtr wing...big chromies...on the back of a tilt tray
anyone here?
plates were "PUR . . . " didnt catch the rest
If it has a red leather interior and its the one im thinking of its packing an R34 GTR RB26 under the hood !
Havent seen him around for ages actually....where did you spot him ?
Spotted x2
you seem like the type...
spotted a blue 34 gtr in Galston Gorge this morning. hothothot
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
