Just wondering if any Coasties happend to have been in gosford last night around 6 - 6.30 and see someone smash into a
white R33 GTST -plates RB-25-MD and drive off??
Well thats the story i was given anyways... lent my bf my car and he picked up up with the front bar all smashed...
said he had it reveresed parked into one of those new park spots @ kibble park near woolies, and when he was inside the shop someone
had lost it and hit it..
OR...did anyone happen to see this car run into someothing??
Would like to beleive his story... but considering how bent the reo bar is..the impact must have been pretty hard (im thinkin he lost it in the wet round a corner or something but doesnt wanna admit!)
Anyways... just thought i would see if any of you spotters had spotted anything!
thanks guys!
Mich
spotted a black skyline at erina yesterday arvo around 4, think it was br3tt off these forums, your girlfriend was driving, i was pulling out of the driveway for supercheap and you went into the next driveway, cant remember the shop tho. i had to stop at the lights and saw you get out of your car and stare at mine for a while lol
i was going to wave but i didn't want you to look at me funny just incase you weren't off the forums lol, nice car btw
Nah wasn't me... my car was running like a bag of shit tuesday and sat in the garage and my girl can't drive manual :/
well anyway, was it anyone on these forums
Edited by weeman1
Maroon 32 GTR on Pennant hills Rd plates MEL ##H cut off some guy in a ricey lancer turning onto Windsor Rd or something. tad grotty, but very nice none the less.
I've spotted that guy before. I think that's an Aussie delivered GTR.
spotted caine... skz01d lol
aka -MONA-'s boytoy, at work today... small world, he works in the same building complex as i do and i never noticed till today :P
Edited by mass_iv
So both of you work on Oxford St right?
Spotted a clean white R33 GTR in carlton lastnite and a black R33 gts thru Hurstville with some bright ass xenons on.... also chased, caught, passed and pulled away from a yukky looking purpley bubble gummy supra all in last nite events....
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
