Spotted LOZ*** pac hwy turramurra - blonde chick driving
Also spotted a maroon 33 with powerplay stickers in Artarmon...gave a toot but I was in 31 and got either a death stare or a wtf stare lol
Turbo Brian, its call traction control lol Wasnt me tho.
Spotted myself testing out a BOV (atmo) on my R34.. I dont know how anyone could use one. Will be making a plumb back head for it.
At least it was cheap!
Spotted a silver R33 in the tunnel on the Eastern Dist on Friday morning. Plates were A**-91E I think.
Then saw a black R34 GTT in the carpark behind the shops in Mascot on Botany Rd. Clean looking, I think it was an Asian guy driving?
And lastly saw a white R32 for just a second on the Cumberland Highway this arvo at about 3pm.
lol place I was yesterday had 4x 32gtrs, and not a single one was running. I'm beginning to think its normal
I aint going anywhere near there then!!
Unfortunately they were all working (including Steveo's) and could make an escape before I could make some money out of em ... :blink:
ok last night on old windsor rd i think i spotted a grey R33 with plates MT***. i think there was another one with blue stickers on the bonnet but can't remember?
Today on windsor rd i spotted a red R33, i let you change lanes, i was in the excel :thumbsup:
and there's a gunmetal 33 out the front of my work building at norwest with chromes..anyone here?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
