^^ i was there around 5ish..
spotted a white R32 GTR on victoria av castle hill today
I almost always see at least 4 Skylines parked along Victoria Avenue in Castle Hill whenever I drive through there (mostly in front of Castle Hill Toyota and the complex next door where Hills are and UAS used to be), and then at least one or two more on the move.
Man, ive seen so many lines on the road, and i flash them with no reply -.-
Probably not in the club i guess, they just look at you like ">.< u wanna race!"
Hmm, gotta start lookin' out for the stickers i guess :)
im getting my plates soon "MRXTCZ" so it will be easier to spot :)
MRXTCZ
I spotted a black(or very dark blue) R35 GT-R on harris st infront of the ABC(where is work) about 20 mins ago.
They look even nicer in person.
Edited by jantolis
spotted a white 33 gtst, with GTR style rear wing at norwest, plates were HWK***..had for sale written all over it..
and i also spotted a blue kitted r33 gtst at the intersection near bella vista waters..i think the guy was on his phone..plates were AH-**-**
i got spotted kinda
the white one with no wing is mine
i work at toyota and so do the other the owners of the other skylines u see
ahh ok i see that out there all the time....so
"I spotted r33mick outside castle hill toyota"
it must piss them off having a quality japanese car outside the dealership instead of just toyotas :)
youve made my day mate :)
theyr used to it no one at toyota drives a toyota
do u work round the area??
i got spotted kinda
You must know Matt Davis then, he's one of the Service Techs there @ Toyota.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
