spotted at like 7:30 ish a white r34 gtt coupe number plate BAR-*** just outside epping heading towards macquarie, was two cars behind on the left lane and stopped at lights so probably didn't see me.
Spotted a light blue r33 gtst in north ryde lastnight around 10pm
Also a white r34 4 door and a silver r34 4 door in pymble
White r33 gtst white southbound on the F3 thismorning at 7:30am
Black r32 gtst northbound on F3 at kariong around 7:45
spotted a silver 34 -FR34KE- heading on to the M2 this morning a bit after 10...
I was ninja :laugh:
yeah spotted i was heading into the entrance from bondi it took 1hr and 15 thanks to tom tom and v-power what were u in? :cool:
also saw a red R34 gt with green P's on newline road at about 2.30pm
wow im such a geek,,,, i seem to be the only one on here at the moment
^ and it did look like B.S too :D
Boy, I'm going to have to wash the car before I go out again. It's so dirty and I didn't expect to be spotted just catching lunch at maccas!
i am teh ninja-shotter :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
