What a day of spotting :)
Midday spotted a dark grey R35 GTR parked in Hillsdale.
Then at 5PM I spotted [KR4-GTR] in Kingsford near the Maccas at the lights, gave a nod to each other haha...all I can say is :):D amazing man, I love it! Ohh and excuse the damage at the front, in the proccess of fixing her all up :)
While they're not skylines, i spotted a vast amount of Muscle Cars yesterday that were on a Cruise from WSID to Pitt Town.
A few standouts were:
A Matte Black 57 Chev with a massive blower out the top. Must of been running something mean, when he was sitting at the lights, the whole car was wobbling..and when he gave it some stick it was the goods (was running fat drag tyres on the rear)
A maroon VC Commodore with a worked off it head 308
A Purple XY GT with orange wheels (looked mint!) - sounded like a weapon too.
And a maroon older Falcon (not sure what model...but an insanely worked 358 Cleaveland, full roll cage, drag tyres, massive bonnet bulge, custom fuel set up. Idles off its head..and the guy had his 18month old baby....ASLEEP in the back seat..i thought that was so f*ckin funny
Saw 2 x R34's at Narellan Town Center on Sat night, and saw a white R34 through Rhodes today..
Also last Thursday I was following a white R32 on the M5 for a while, then later spotted the car parked in Kogarah. As I was leaving work he pulled out behind me and drove with me for a bit.. Pretty funny!
Good to see a few skyline's around there. I just moved into that area and all i see are ford/holden/utes... shits me to tears!
Yeah I live around there, hardly ever see Skylines out and about so it's pretty exciting when I do haha :)
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
