You guys from Riverwood ? always spot a silver R33 decked on chromies with GTR front bar in Riverwood.
im from east hills but my familys in rivo and yea u prob spot it outside queen street racing L0L all there cars are decked on 20s with chrome and shit
spotted a really loud black 32 at pennant hills this morning.. looked very clean! plates were GTR something.. very nice ride, dude/dudette!
Yeah I spotted that this arvo.... Number plate was GTR.32X, very very loud, looks as though its got an extremely free flowing cat in it aswell lol, very wide rear tyres and super super clean....
Made my r33 gtst sound as quiet as an electric car when i was following it
stopped a blk r35 with the plates vr38 or 36 on pennant hills road. looks crazy in person and in black
I saw that same R35 a few months back in Girraween - plates are "VR38"
It looked HAWT!
spotted a nice purple gtst? r33 on bangor by-pass looked hot
yeah i see it all the time, its parked next to menai mcdonalds all the time, must live there
does this look like it? must be coz not too many around....
and yes i'm a stalker
oh and to the silverish coloured Stagea on gladesville bridge today with numberplates " @.888"
1st sounds like the stagea is next to stock,
2nd your cars automatic
3rd its double demerits
4th i dont street race (but i may drive over the limit as everyone does from time to time)
5th if i gave it in the right gear you wouldn't even see my rear numberplate lol
We don't want the volvo on steroids to cause a loss of someones lisence. ive already been there and done that, not worth it dude
cheers
cheers
LOL stageas......
yeh that the one ;o first time seen it the other day lol
Spotted a clean looking white R34 this morning at just before 8am i think, in Hornsby on George Street. (looked like URAS front bar??) :)
Im pretty sure that would of been qantas/hempy he works in hornsby.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
