Four of us ran into each other at Penrith AutoBarn this evening (Thursday). Good to chat, fellas.
I'm terrible with names, not to mention number plates. But there were four R33 GTS-Ts. White s2, Burgundy S2, Gunmetal-ish S1 and white S1 (mine). A good yarn, and some useful advice for the young bloke in the Burgundy S2, who's having misfiring problems, especially under boost.
David
this mornin i saw:
blue 32 gtst AWR21Q i think at georges hall shops
and a white stagea following me on rookwood rd near the lidcombe turnoff
around 330-4 i saw:
33gtst SXY33T on henry lawson drive just after lights for aldi
a white 33 gtst plates azl *** i think on newbridge rd
gunmetal 33 gtst with a red stripe on new bridge rd plates arq*** i think.
Haha yeah that was me in the white s2 gt30rb plates .. It was a good chat but was too bad i was meant to be inside working lol
Saw a black R34 GTR at Horsley park shops, had gold volk rims, kakimoto exhaust and victoria number plates
there was also a white R33 gtst parked infront of it with a carbon fibre hood
sweet rides VIC
spotted a silver r34 gtt on parramatta road around 3:00pm with an SAU sticker on the window.
also did some 34 gtr shopping today, spotted a midnight purple one and a kr4 silver one at E&M motors on parramatta road. nothing spesh though.
Edited by KR4-GTR
Spotted Cassbo's car parked next door at around 7.30pm tonight.
Also spotted a white V35 coupe and a white R34 four-door in Strathfield around 8pm tonight right near the train station - didn't get to see the plates, I was watching the road and scanning for a parking spot at the same time...
a few months back i rember someone complaining about an ugly ugly blue riced out r33, someone said it was probably the fear god r33..... well found this stupid video on youtube....
how come ACA or TT never used this footage?
spotted a silver r33 coupe on carlingford rd approx 6:40pm heading towards pennant hills rd.
Also yesturday was spotted by a silver r33 on old pac on way home from coast at like 5:30 ish he flashed his lights sorry for not returning the flash and late wave i had sun in my eyes lol.
Hey Glenn.
I'll drop by and ask you some advice soon. Nice S2, by the way...
David
fkn lol
I love how the comments are all "waht a riced pos"
/i didn't bother to read all the comments but I was expecting at least 1 "you're a moron who just put evidence of hooning on a public road with a car you spot the ugly from a mile off and p plates, sending link to local cop shop to get idiots like you off the road and ruining our rep, kthanxbai"
Just spotted this tool driving down old northern and castle hill road at about 9am. White R34 GT, Green P plates, Got a couple of stickers on the back, Blue anodised rear window wiper.....
LOL hey that was R34Liner lol
Hey Bud I was in the stealth Kia Rio Today lol
Took a pic of you aswell just for fun, Car is still looking great. Just watch out for the magnet p plate you have on it, i had a couple of magnets and they used to bake onto the paint pretty bad.....
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
