spotted a Metalic Olive Green R33 at around 1pm driving west on showground road in tha hillz...
pretty decent paint job, saw it for a second but looks good
spotted a white r35 driving through telopea past the shops and school around 6'ish, then a black r32 at james ruse dr on ramp near parra, a silver r33 along carlingford rd followed by a white stagea and a burgundy r33... busy 45mins period lol
spotted a smashed R33.... near botany I think.. cant remember was on the way home from the airport
I think it was around Roselands or Beverley Hills when we saw that.
all on friday i spotted:
MADGTR turning near the Hills Lodge
Bayside Blue R34 GT-R KIW18U
Blue V35 with LMGT4's on Parramatta Road
Black R34 GTT with VIC plates near Auburn Maccas
Silver R33 GT-R on the M4
Silver R33 GTST RU3L8R
and a yellow R34 GTT near Croydon AIFANG
spotted R34LINER again on oldnorthern road castle hill, not sure on time but around 1.30-2.30ish, had a lady friend in passenger
On Sunday i spotted one of those 2-tone grey 33's P plater with a big green sticker on the back window that said 'FULLY SICK' LoL
Also a silver 33gtst came past my work today ass end was low as...sounded good.
ahh yes on the way to uni, didnt see you tho? were you in the line?
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
