Spot me!!! Off to photoshoot with the 33 down at the 'gong in like, 6hrs....
Also seen the yellow one mr Eric is referring to, twice in last fortnight, both times on penno rd.
:dry:
ehh yeah?
lol
ok
so 2012 was okish?
Yea, it was overly Hollywood for me :| but my taste in movies is very critical, so yes ask others what they thought before you spend the moneys...
i spotted a skyline today, it was rad
A good spotted day!!! Spotted R32 GTR goin thru the harbour tunnel this morn at half 7.... White R33 cruised past during the car shoot at the bellambi? boat ramp, and spotted SXY33T and BEH02T (or similar) in mt Ousley...
A good day all round!
