Spotted Lizzy in her red 180sx this morning at the big dipper on new line road, i didn't know your a country girl aswell?
yaaa... im from the Dural area. Quite a few of us around that area now!
ps. you didn't even wave back! unbelievable!
lol
Spotted a white 33 being booked by the po po heading north on Southern Cross drive just after the airport
Also a few V35's rolling around the sylvania/chronulla area.
Funnily enough no one as yet has spotted by feck-off-red v35 :thumbsup:
lol
Hahahah i didn see the wave, i only noticed the number plate at the last second lol and there were idiot drivers infront of me who kept brakeing up the hill
lol
im working at galstone at them units behind the village shops
also spotted a r32 in the morning on carlingford road and also today in the arvo a r32 gtr at the mechanics opposite st george tafe
ahhh at the moment ive booked out about half of hills storage at galston, i was there today,,,,,,
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
