Spotted GD2ILA 33 GTR on comenarra this morning waiting at ryde rd lights round 8am. Always spot you. I was in the black 32. I'm usually in the sprinter though.
Also spotted a nice black 34 GTR round 630pm at lane cove rd/epping rd intersection.
spotted black R33 GTR with black rims and yellow decals. had ACT plates.
Looked like a series 3. Saw it in Moss Vale around 3pm. I was in my FTO. Awesome looking car mate.
SPotted R34liner aka Aron turn onto showground road yesterday (wednesday) in the arvo, I was honking at you from the CLS but I don't think you realised who was honking at you...
Just followed a nice clean 33 4 door on the m5 this morning.
Also saw a very nice 33 GTST yesterday that was pale blue with a white shopping list on the door.
haha yea i dont usually look for ppl in CLS's :P
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
