:ninja: caught the rear end of you :laugh:
Yeh i almost missed you too been a while since i seen your car think it was the crispy cream to the gong cruise over a year ago, still havn't seen another blue one around other than ours.
Yeah i know its been ages! i saw non-turbo one at stanhope shops the other day lol.
Spotter a nice lowered blue Fairlady Z on the The Comenarra Parkway yesterday at about 5PM
If it's the 350Z I know, it isn't lowered, it just has Amuse front bar that sits pretty close to the road :ermm:
Has Fairlady Z and Nismo badges on the rear?
Spotted KIW 18U Blue R34 GTR on Windsor Road this afternoon
Then this evening spotted BJC 10S on James Ruse and then on Windsor Road
Silver R34 GTR V-Spec Standard I think
I was in the Evo 9 Champ
If it's the 350Z I know, it isn't lowered, it just has Amuse front bar that sits pretty close to the road >_<
yeh sounds like we are talking about the same one! except this one definitely looked lowered :cool: ....but then again I was behind him!
forgot to post this yesturday...
Spotted a Gunmetal Grey R32 GTR number plates - R32GTR on Pennant hills rd around 1:30ish in the arvo.
Gave a wave but not sure if you sore me cause of all the traffic.
SN33ZZ is Hempy's old plates, he got a new car and I don't think he kept him. Don't know the new owner...
Spotted a MNP3 (? - was 2 or 3) R34 GTR at chatswood today
Spotted Mitch Mr Moo, gave a wave, dunno if he saw
Spotted Demir's R35 outside his shop after having an argument about wether or not he has one with a co-worker of mine :)
Spotted Demir's R35 outside his shop after having an argument about wether or not he has one with a co-worker of mine :happy:
no i did not see you. where did you wave.
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
