Today I spotted a dark blue s2 R33 GTSt on the bridge at Toongabbie (rego BFE-??? or similar) and a silver V35 fuelling up at the little servo on the corner of Gilba and Targo Roads in Girraween.
haha that was meeeee
Only 1 in Aus believe it or not original build No#001 R34 ZTUNE GTR in Sydney !
I've seen this guy around too! Has red vic license plate "ZTUNED" I think
Missed a green light cause I kept looking at it :D luckily no one was behind me.
that one has apparently left AUS for good and that was build no#014 I think, build no#001 is now the only 1 out of the 20 built in the world left in AUS
Edited by GMASTR
there could possibly be two z tunes in the country at the moment
build #004 "ZTUNED" from vic... apparently has only been rumours of sale, but currently still for sale
build #001 just came up on SAU http://www.skylinesaustralia.com/forums/tu...01-t336373.html
spotted 2 33GTR's yesterday to my delight, one near UWS parra with the plates: BPP-485 and one that i didn't catch the plates on parra rd near the audi dealership
both looked pritty damn sweet.
