spotted a grey r32 gtr friday night at marayong indoor sport centre, a white r33 on quakershill parkway bridge this morning and a blue r34 gt on gret western highway that i got a nod from :(
Drove a few hundred meters with a Yellow R34 GT-T with a nice vented black hood behind me down SunnyHolt road on Sunday about 3.45pm. I was in my white R34 GT with the carbon hood :)
Spotted a white R35 GTR this morning filling up at BP Fairy Meadow
pretty sure he lives sum where on bally road,
think i seen your car at fairymeadow wollies yesterday
we were in sydney 2day, spotted heaps of lines but cbf writing details lol
heheheh we passed your car at top ryde shops as we were leaving on sunday :ermm: damn stalkers!
I keep seeing Eric in his R33gtr as i drive home through Ryde too ;) though there's usually too much traffic in the way to get his attention!
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
