Spotted a mightnight purple r33GTR Getting pulled over by highway patrol in wollongong at win stadium :/ i drove past in my r32 gts-t and felt so bad for the person lol :(
drove past again 20 minutes later 2 see the car parked down the road with no1 there
any details on that lol?
Might be me in the white 33 GTST, are you usually in your GTR?
I'm pretty sure that was you behind me yesterday arvo heading up botany road. I turned off to head towards the ED and you went straight on.
I don't think that was me.. Straight on in the direction of Mascot or Botany?
I saw a four door R34 driving passed the TAFE at Kogarah yesterday going onto President Avenue some time between 3:30pm and 4:00pm yesterday. It had a SAU Sticker on the side mirror too!
Edited by JDM34
Spotted a wine red s1 R33 GTSt today on Richmond Road in Blacktown, driving like a bit of a dick. Sped past me on the left then was at least 10-15km/h over the speed limit as he headed off into the distance.
:down:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
