With the increase in number of "I spotted so and so Skyline" this is the official one for NSW (well I hope so)...the other states have one...well Victoria has one...
so start off...
I spotted a Maroon R32 GT-R around the South Strathfield area. I need to ask dude - why did you change your light set up? Moving the indicators to the outside hotplates looks wrong. Especially when braking; I thought you had 3 busted taillights (the one on the right middle is out btw.)
https://www.sau.com.au/forums/topic/29195-official-nsw-skyline-spotted-thread/
I saw two R32's on the Central Coast on Tuesday night heading toward Mingara,
Both had AUTOSTYLE stickers on the sides, both had personalised plates, but I cant remember what they said.
Perhaps UR..... something...
I see MADGTS all the time on fullers rd. But no one waves to me when I am in teh exa.  :D
That's Zane. He's on the forums somewhere and comes to track days at EC.
I spotted fatz new toy. Beastly thing I must say!
CerealKiller - that tail light rewiring your talking about is standard on the aussie delivered GTRs the outer one is the indicator and the inner is the brake light with the lil square as the reverse light
IMO i think its oright i like it cause it gets rid of the reverse lights next to the number plate and there is a nice panel that finishes off the rear bar around the number plate mount instead of having big gaps up the top where the number plate lights are.
oh yea and i saw a nice sliver GTR in the back streets of gladesville yesterday i think its from BD4s
anyway its just my 2c
:D
I spotted a midnight purple GTR in Longueville... It was uncanny... Exactly like my one!!!!!
You'll never believe where I saw it though......... IN MY GARAGE!!!! How freaky is that???
2 GU UP , you're kinda hard to miss lol
I was in the saab...but we do have an SAU sticker so that's no excuse.
You have to wave, its one of the forum rules.
(except for fatz, if you see him on the road keep out of the way :( )
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
