I spotted quite a few today, a nice maroon r33 plates mz71ne I really remembered that one because it was one hot real estate chick driving, saw a maroon r33 next to soil n stuff in rockdale, grey r33 on princess hwy st peters we cruised together for a couple minutes then I had to turn off, a white 4 door r34 at rockdale, and a few days ago a white r34 4 door trying to give me a run on forest road bexley.
Spotted a white R32 GT-R with white Sparco wheels earlier tonight in Northmead - it could well have been GTR-Kat, except she's changed her wheels and I'm guessing her car would always be clean, unlike the one I saw tonight... I should have taken a photo.
hahaha was mz71ne this chick?
Yep :D, shes leasing out the house next door to my invesment property, I think I need a home :D hahaha lol, (cough cough) I think I need to do some repairs next saturday during inspection time (cough cough) :D.
haha its all good I'll just wait till Saturday, It's a date :D haha lol, I should have taken a picture our skylines were parked together.
<br />Hahaha yeah she does. She's my sister's agent for her rental property, just hang out around the cafes in Dolls Point and you're sure to cross paths! <img src="http://www.skylinesaustralia.com/forums/public/style_emoticons/default/ph34r.gif" /><br />
<br /><br /><br />
as if stalking skylines isnt bad enough, now we are offering tips on how to hook up with their hot drivers.
not complaining though :P
heres a shocker i saw on elizabeth st surry hills the other day
and in front of rhodes shopping centre
Ahh so you're the person with the gunmetal GT-R with black wheels, nice car mate. I work in Chatswood, I've seen your car a few times.
Also behind ABC
Yeah man! see your car round heaps as well.
My gf rang me up in a panic saying she say someone driving past her with my car, turns out it was yours im 99% sure. ha.
Hopefully see you out there man, Gtr is usually out on the street with a evo 6.5 makinnen and soarer on the weekends.
what have you done to yours man? sounded good.
so which of you drove down mowbray rd last night towards lane cove north? was ghetto bbq'ing on the veranda :)
Spotted the sticker bombed front bar white R33 with orange wheels on Victoria rd headings city way about 6:30pm. Front bar looks good mate!
cheers mate :)
That's joelymoely
ugh herd that guy is a epic duche :P hows that engine of yours coming along?
If the car was quiet then it was me, with white front lights?
was fairly loud (was no ambient noise though so anything would have seemed loud) but did seem to have HID's so may very well have been :) looked the goods :)
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
