I saw a Yellow R34 on the M4 heading towards sydney on the either the 23rd to 25th Dec cant remember exact date, it was just passing the Mulgoa Rd turnoff in Penrith.
Also seen an R32 gtst on batt St Penrith. looked pretty stock, gunmetal grey.
And I keep seeing a maroon r33 gtst passing my house going pretty fast ( High RPM sound, probably top end of 2nd gear = around 80km/h?? heading towards Southlands in Penrith. Havent seen him in a few weeks, lol probably got cought by cops
Wheres your house, might be me???
hey roy.....you might know who owns the R33 in richmond..always parked at the richmond pools? it is grey and has a big skylinesaustralia.com sticker on rear window
sounds like Majanal to me :(
I spotted a grey skyline about 100km north of cooper pedy....hang on....sorry....wrong thread - I need to find the SA one :(
today i saw r33s in penrith, a black one on Mulgoa Rd, it was a series 2. the wheels where a sort of bronze colour.
I got the plates of this car.
Also on High street, I saw a Silver r33 gtst just past the good guys. Didnt get a good look because he was going in a different direction ( towards Great western highway )
Then I went to the good guys and i saw a dark coloured r33 gtst series 1.5 parked away by itself.
That is most likely the 1 thats forsale over opposite Penrith Gold Course. From memory it doesn't have a standard rear wing, more like a GT Wing.
Mine hasn't moved at all today, im too frightened to even open it to let the heat out coz of how hot its been today.
I seen ya a couple of times PranK - but you don't wave back you biatch ! ha ha ha ha ha ha he !
Seriously - I been looking out for you PranK - but never see a WRX with SAU plates on around my area ! ha ha ha ha ! Ooopps did I say that !!
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
