I saw a Yellow R34 on the M4 heading towards sydney on the either the 23rd to 25th Dec cant remember exact date, it was just passing the Mulgoa Rd turnoff in Penrith.
Also seen an R32 gtst on batt St Penrith. looked pretty stock, gunmetal grey.
And I keep seeing a maroon r33 gtst passing my house going pretty fast ( High RPM sound, probably top end of 2nd gear = around 80km/h?? heading towards Southlands in Penrith. Havent seen him in a few weeks, lol probably got cought by cops
Wheres your house, might be me???
hey roy.....you might know who owns the R33 in richmond..always parked at the richmond pools? it is grey and has a big skylinesaustralia.com sticker on rear window
sounds like Majanal to me :(
I spotted a grey skyline about 100km north of cooper pedy....hang on....sorry....wrong thread - I need to find the SA one :(
today i saw r33s in penrith, a black one on Mulgoa Rd, it was a series 2. the wheels where a sort of bronze colour.
I got the plates of this car.
Also on High street, I saw a Silver r33 gtst just past the good guys. Didnt get a good look because he was going in a different direction ( towards Great western highway )
Then I went to the good guys and i saw a dark coloured r33 gtst series 1.5 parked away by itself.
That is most likely the 1 thats forsale over opposite Penrith Gold Course. From memory it doesn't have a standard rear wing, more like a GT Wing.
Mine hasn't moved at all today, im too frightened to even open it to let the heat out coz of how hot its been today.
I seen ya a couple of times PranK - but you don't wave back you biatch ! ha ha ha ha ha ha he !
Seriously - I been looking out for you PranK - but never see a WRX with SAU plates on around my area ! ha ha ha ha ! Ooopps did I say that !!
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
