Spotted two R32 GTR's (From what it looked like), One black with a SAU sticker, the other silver driving on Camden Valley Way heading towards Camden. Spotted at the Raby Rd turnoff :D 3 days ago.
Just saw this lol, finally been spotted after driving every day all in different areas of sydney haha. This was me (dark blue gtr) and a mate coming back from unigroup after the his (silver gtr) had been tuned... we saw a few skylines that day also. actually we had a fuel pump issue at hungry jacks on cowpasture road and noticed a blue r34 gtr and a white 33 gtr at the set of lights there.... good to see so many gtr's and gtst's still around.
Scott
Hey M8 those guys have been importing cars since around 2001-2002 i used to live on the coast and went to a few dyno comps held at TM AUTO SPORTS at tuggerah and those guys used to come along. i used to have video of the comps as well but i have no idea where they are now.
I saw two R32's on the Central Coast on Tuesday night heading toward Mingara,
Both had AUTOSTYLE stickers on the sides, both had personalised plates, but I cant remember what they said.
Perhaps UR..... something...
if this was the badge then they have had some really wicked cars back in the day. ( they had a 10 sec bright orange fairlady used to snap 3rds without blinking an eye!!!)
Also........... Here is one of their Skylines.
Spotted a white 32 gtr at parra uws carpark around 10.30am yesterday a bayside blue 32 gtr around 12.30pm yesterday on cumberland hwy and another grey 32 gtr turning from woodville road onto hume highway around midnight last night.
Edited by BK1990
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
