2 R33's came through Robertson this arvo (with a white 201? WRX Sedan)
One blue, one silver.
That would of been my mates, silver 33 gtr and a midnight blue 33 with a white 2011 sti after a maq pass!
GTR 600 I think were the plates. Grey 34GTR gave us a beep. He was on the way back from Wisemans as we were pulled over on the way there.
Once at Wisemans a white 32 GTR parked up with us that left early.
Edited by FordyR31
I see a few skylines around the St George area daily, always different ones and a couple regulars, I've given up on trying to wave or advise of the spotted, coz when I do they just look at me like who are you most likely they're not on here haha lol.
or they might shoot you lol
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
