Spotted a grey r33 gtr on the way home from work on the m5 this morning. Sorry I didn't wave back. The gaveyard shift is killing me.
That was me mate also on the way home from a 12hr shift
Saw a Bayside Blue 34 last Thursday on the Northern Beaches with plates GR34TR, nicest Bayside Blue I have ever seen :yes:
hey yeah i remember seeing you too, at the last minute you caught my eye, i was looking for a street to make a u turn in :)
who ownes the RB that i hear going down mowbray road in chatswood, sounds like you come out of orchard rd.
every night almost on limiter and im 2 streets away haha
sounds awesome tonight it was at 8:14pm :P
I am around that area in my 34 GTR but i was not at that time, i leave artarmon at 7 and go up to the lights to go onto pacific highway
Spotted a silver s2 R33 with what looked like blue Nismo stripes, turning off Seven Hills Road (Prospect Highway) onto Johnson Avenue earlier tonight, around 7pm.
hmmm dont think its you then its definatly east of the pacific highway, so you do the central coast to sydney everyday in your 34?
White R33 GTR I see all the time in and around Fairfield, Asian driver with shaved sides like Taeyang. I can tell it's the same GTR whenever I hear it coming my way lol. Just went past my house this morning at about 8:10 AM from Hamilton Road turning in to Rawson Rd. First 3 characters of plates is GTR-something.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
