That would have been Ian (aka "StageIan") in the red Stagea, Christian.
I see this car all the time. Does it have a black front bar? I saw it the other day parked outside of Hardware and General in Brookvale, and then again out the front of my work at Neutral Bay. And I think i've seen him in Seaforth where I live too.
I spotted a white stage C34 the other day as well in Neutral Bay on my way home from work, that has a SAU sticker on the rear quarter window. Looked like an Asian chap driving. Gave the wave, but I don't think he saw me.
Cheers,
Shazza
Edited by XS80ST
Could it be love?
perhaps, (no homo)...
what is with Skylines, I don't think they're that sexy looking but I'm obsessed with them.. (R35 R34 GT-R excluded, because they're sexy looking)
Nah Gibbon sorry to burst the bubble but these were parked at the same place same time.
Bummer.
OT: same day spotted and gave big thumbs up to a gunmetal 33 and received a big thumbs up and a grin back
headed west on the M4 at about 1:30ish.
Cheers,
Shazza
It does, yep.
Indeed it does have a black front bumper, part of a new kit he's slowly piecing together as funds (and time) become available.
BTW, Stagea spottings have their own thread here: http://www.skylinesa...pot-the-stagea/ - that way if you see someone and want to know if the spotted you, you'll know (assuming they haven't posted here).
I spotted two V35s tonight, one a black coupe, and one was a silver sedan. Both on Pennant Hills Road, if I remember correctly.
Spotted Black R34 XMY-34X running Starcorps I think on Parramatta Rd, go right down Woodville Road a few days back. Whoever you were, I wanted to wave but was too shameful to do so in a silver Corolla :closedeyes:
last night saw heaps of lines in the CBD, sydney.
one black one 25GT, with green p plates sounded so weak (or...harsher word is gutless) (no offence)
silver 33...
black 33 with mesh wheels
probably one or two more can't remember now - not a single wave though.
Just spotted an R34 GT-R (either very dark silver or gun metal grey) about to be loaded onto a tow truck. Was about half past midnight, near the intersection of Kissing Point Rd and Silverwater Rd, Dundas area.
(null)
