Heh see!! just think what a little creative thinking could have done... you could have avoided the train for starters, then you could have ended up with a new lad and or car.... just think of all the spare parts ;)
Hahahahaha....i don't know what i could have gotten from him...it was a maroon stock looking s1 skyline :D
Hahahahaha....i don't know what i could have gotten from him...it was a maroon stock looking s1 skyline ;)
Ok, i'm not even going to try a whitty response to that one.... its tooo easy to set up... i'll be quiet now.... oh god it hurts...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
