Silver R32 GTR BVB 41Z inalls lane and yarramundi lane between Richmond and North Richmond. You sir are a wanker. If u want to take a run up before over taking a car doing 60, maybe u have time to pull into the other lane earlier than up my arse. No wonder imports get a bad rep.
Edited by FordyR31
Perhaps we should have a "red list" until they appear and beg for forgiveness?
  • Like 1
I dont know. Think it would be useful? The only reason I don't report people being dicks in Skykines is the impact it has on the rest of us. Would hate Tracey Grim.... to get a hold of info about a Skyline, that's a repetitive story for 6 months!
