Spotted a black 34 parked at c o c kle bay car park last night....plates were GTS 34 or GTR 34 can't remember....something 34!  hehehe...you're lucky i was in a car driving past, or you'd have come back to find your wipers up! :rant: b
http://www.skylinesaustralia.com/photopost....php?photo=2622
spotted:
20 odds skylines at Oran Park driftland including teh winner drifter a grey r33
Yellow r32 gtr, kpgcxyz110, black 31, red 31 in Panania yesterday
About 15 Skylines, and a Bluebird race car at Gosford today
:rant:
spotted:
20 odds skylines at Oran Park driftland including teh winner drifter a ghey r33
:rant:
Fixed :)
spotted last Saturday.... white series1 R33 GTST....had some kind of aftermarket rims, and the number plate "ED"-something..
was exiting the Cumberland Hwy to some road that went to Windsor and other places, and it was around 6pm i think??
Spotted a Maron 33 GTS-t around 6pm driving onto James Ruse Dr. No Plate was GTS 10P
Thanx for honking your horn dude
Also I seen a Gun Metal grey 33 GTS-t which parks near my work at Seven Hills reg No API 11T I think, Any1 from here belong to any of these fine Motor cars?
Well I have spotted my own car!!!!!!!!!!!!!!
You all know East-Bear right? Well check out the Japanese East-Bear site! My car is on it!!! (Powerplay are official East-Bear importers and were working on my car, thus it's in the pic on the East-Bear site!).
Sweet!
Your car might be on the East-Bear site too! Check more pics here:
http://www.east-bear.co.jp/info/Australia/.../powerplay.html
saw a HOT looking yellow gtr on the back of a tilt tray truck - no plates
heading from Liverpool in the direction of Fatz place
must have been stolen : P
word is, the owner blew up the engine trying to beat a 350Z cab.
Christian
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
