been at CRD the past two days and all i have to say is OMG
EVLR34 has the lumpiest idle i have ever heard
RH9 is just gorgeous
Black aus delivered R32 GTR there too looked like GTRRRR (didnt have plates on it so i wasnt sure if it was or not) which would have to be one of the best R32s ive seen
is RH9 their project car ??? or is it a customers car ??
cause EVERTIME I GO to CRD...it is ALWAYS there...
saw EVLR34 at powerplay last week...NIIIICE.....not a big fan of the blue rims though !
shit...all this time i thought barbie iz a bitch was a guy...... :headspin:
Guest barbie iz a bitch
umm thanks!! :)
OKAY! What the hell was that machine of an R33 I saw in Hornsby this morning????
Plain looking 33 (series2?) with a big black "insight"? sticker along the side.... As soon as I saw you gun it (or heard you gun it actually) I went "F#%K!"
So yeah, can anyone fill me in on this machine, by the way it was standing up under throttle, it seemed to have a bit of go in it....?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
