hey guys where in the south eastern suburbs can i find a good reliable place to do a wheel alignment? bob jane in moorabbin did a good job last time but it cost me $120. the place i went to before that i dont even think did anything and just charged me for waiting. any ideas?
https://www.sau.com.au/forums/topic/292132-good-wheel-alignments/
If you don't mind driving, Traction Tyres rowville does an excellent job, they are not cheap, I think I paid ~$110 for a 4 wheel alignment but they tune the settings carefully ;)
EDIT: at Traction Tyres you can actually see them working...lol
so u'd rather have a dodgy $60 job than a proper $120, only to have to come back 2 or 3 times which is gonna cost $180 down the track?
u misunderstood, im looking for a place people recommend. price isnt the biggest issue as long as they do a good job. also im trying to find a find a place that does a lot of imports rather that changing mum and dads tyres every day
I second this.
Yep traction - they've done my alignments twice now - no issue's at all, had a good chat with me about what i wanted from the car.
Could feel a noticeable difference as soon as i left the place (lots of adjustable stuff on my car)
I went to Bob Jane Moorabbin May this year, salesman Adam, guy that did the job was Darren who is good with GTRs, did all 4 wheels with printout, $75.
Try there again.
No one does a good wheel alignemnt anymore - it's all rubbish these days.
You can take the same car to 6 different places that have these lazer alignment machines and all 6 places will give you a different result but each of them will swear theirs is acurate!!
+1 for traction. After having problems with scalloping tyres (and thinking it may have been a collaped shock or a wheel bearing) they had a look at it and diagnosed it for free, and where great with getting it fixed.
Will be going back soon to get my brakes checked.
Edited by baron25
well i ended up back at bob jane in moorabbin and i it cost $75 for a 4wheel alignment n they did a brilliant job. also the fellow who did it actually had a chat with me afterwards and told me how i could fix a problem with my control arm. i didnt fully understand it first but then he dumbed it down and showed me. good bloke. id recommend this place to anyone in that area
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
