Which wheels look best on a white R34 GTR?
48 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Guys let me know what you think I should put on the car, wheels are not my thing, and I have a 2 sets of R34 wheels I will sell one set and buy probably one of these. The 3 Options options are.
1. Wedsport 55M http://www.weds.co.jp/products/wedssport/sa55m.html
2. Wedsport SA-67R http://www.weds.co.jp/english/products/wed...r.html#ch_wheel
3. Enkei GTC01 http://www.enkei.com/gtc01.html
I look forward to your vote.
Thanks
You are so gay for Weds wheels aren't you Pauline.
Out of those three, I think the new Weds SA-55M's would look the best against a white BNR34, however I would personally bypass them all in favour of a nice set of TE37's in 18 x 9.5's for track use.
Buy a full set of each, Paul, but please make sure they're in a fitment that I can transfer onto the LOLwagon, okay? :P
Honestly? I LOVE the Enkei's the most, but they're becoming common. That doesn't turn me off them any less, but I still like to be different.
Hmmm, thinking back - that doesn't really help you at all, does it?
I actually like the Enkei RPF1, although I shouldn't say that because I have them on my car and their not to common.
Also I've found Enkei's to be reasonably priced for a high quality Japanese rim.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
