hey all
just bought my new r33 gts-t series one
im having a lil flashing icon which turns out to be the 'check oil' icon when im boosting sometimes
maybe its the way im driving it but it sometimes turn on and sometimes doesnt.
ive checked the engine oil level with that lil metal dipper and it seems to have recent healthy looking engine oil
anyone know why this is?
cheers
Look at the level when cold (ie. wait at least 10 minutes after shutting engine off). Sure it's not an oil pressure warning? because if it is you definitely do not want to ignore that
edit: If it is indeed oil pressure, I'd hate to say, but you may haee brought yourself a lemon.
hey
so how do i no if its the oil pressure or not?
yeh i have a apexi powerfc with the controller, dun really know how to use it
car has had new engine put in not a year ago.
shouldnt be knocking or anything like that..?
its that orangey icon at the top right of the dash.
any one know?
so its the check engine light?
hoping its not set to high knock levels or you could be changing the engine yet again.
would recommend you get it to a tuner pretty quickly for diagnosis and possibly re tune.
yeh i just looked at it
its the 'check engine' icon flashes SOMETIMES
wen im boosting.
car has highflowed turbo, turboback exhaust, powerfc etc
it was tuned before but last owner put a fmic on and it hasnt been tuned yet.
he recommended that i get it tuned aswell.
so im better off if i take it to a shop and dont drive it to its edge just yet?
you can check your knock levels on the hand controller display, go to the correct page and it will give you a read out with peak hold, but if your light is coming on then its +60 or thereabouts.
standard AFM? doesnt the "check engine" light come on when the afm gets maxed out aswell?
How quick is it flashing. I cant remember which way it is, but one is knock, and other is AFM from what ive read up.
this sounds similar to what my car used to do before....the tune wasn't the best and it knocked every time around the 40-70 mark....got it retuned and now barely seeing any knock.....so as others have recommended take it to a decent tuner and get your power fc retuned.....and save yourself have to slap in another motor
that light is ur piston saying hi, if you ignore the light long enough ur piston might actualy decide to exit the block and say hi in person.
definately dont drive the thing hard if its knocking, take it for a proper tune :(
hi,
covered to death in the powerfc faq (in my signature) read it and check if its the AFM, Injetors or knock causing the engine check light to come on
to clarify, the engine check light is orange, this is a warning sequence light, as the colour is orange
the oil pressure light, is red, and is a critical sequence, as the colour is red
the orange engine check light is used (with the powerfc) to identify maxing sensors, broken sensors and excessive detonation
isolate the cause for the orange light flashing by using advice in here and the FAQ
have the hand controler? you can adjust it in there what knock level it comes on. if its set to 50 or somethi ng you need to have a look at the tune.
you cant adjust the threshold with the hand controller, you need datalogit to do that. standard setting in the pfc is anymore than 60 knock flashes the engine light
use the temp adjust to take a couple degrees of timing out until you get it tuned
so knocking is a normal thing?
im pretty sure its standard AFM
the powerfc i have no idea how to use, but the check engine light flashes a lil bit
and it doesnt so much knock on the hand controller.
how do i check wat level its set to? also ive read that FAQ briefly but dun really know wat im after
it siad something about hitting the limiter and the engine is knocking slightly?
since the ECU has been changed, would i focus on the handcontroller 's readings or the dashes??
my r32 didnt used to do this? but that was stock :P
not really sure wat to do atm lol
that tune is coming tho
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
