I'm Facing A Dilmemma Now That I'm A Member.
Do I Put The SAU Stickers On My Car Or Not.
I Usaully Hate Stickers On Cars.
But I'll Like To Show That I Am A Member.
Need Input Guys.
Do These Stickers Come Off Easily?
Not Every Word Needs To Start With An Uppercase Letter!
Stick them on a window, they come off easily with a razor blade.
Has anyone noticed if they get less attention from the boys in blue if you have the SAU stickers on?
I would have thought it was the other way around :)
Hard Kandy and PHD stickers used to be a boon for cops pulling over cars on a weekend morning :D
I would have thought it was the other way around :D
Hard Kandy and PHD stickers used to be a boon for cops pulling over cars on a weekend morning :)
Haha agreed!
I'm trying to keep my car clean of stickers sorry guys! :)
I've only put one on myself and I have one which came from the last owner in Japan so I haven't taken it off yet haha.
Put the sticker on and represent, but only if you plan to drive responsibly! :blush:
thats why i put mine on :P to control my urge's of spirited driving :)
plus i have custom plates, so im just digging myself a hole if i drag every holden that rev's there engine at my wagon!
oh yeah and welcome to the club. its your 1st post. and your already paid up. good stuff
Of course you will man, where do you think membership money go's? To pay the filth under the table :blush:
So next time if I get pulled over, I'll just get out of the car and walk towards the back of my car and just tap on the SAU sticker and they will understand? :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
