  • Replies 1.4k
Posted Images
Pfft if you can find one...
P.s I m looking for if anyone knows where one is! Contact me please :)
http://www.my105.com.au/classified.asp?id=...5&feature=1
I should really focus on my work, at work... :)
Hope what you are looking for...
Seems Glenney in the pulse evo has trouble selecting with the PPG Gearbox too...Can hear it in the vid a couple down from the V8 vs Rotor
Sort of, I wanted to see the Pan Speed and R Magic cars but I will keep an eye out on the site.
That RX7 v Supercar vid is pretty telling of what affect weight and no tyres does for the Supercar. You see the RX7 is able to go soooo much later on the brakes and carry so much more speed mid corner.
So who is going to be the first to throw the mortgage at an R35. Stroker kit with bigger turbos, PPG gearset. Completley gut the thing and swiss hole it with lexan windows, carbon, titatium and as little cage as you can get away with.
my thoughts exactly. and will they do it by next years superlap. and even if they do, will the new platform be enough of an advantage to overcome what little development time a 12 month build-tune&test schedule would allow?
As last reply to this site, I'll do a 35, but by no way on your recommendation - enjoy - see ya's next year
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
