Recently ive been very keen to put a cold air intake from my throttle all the way down to the k&n pod under the chassis. I got quoted $300 to get it done on my r32 gts. Before i go get it done, i need to know - do you get any performance gain out of it? ive been told otherwise...
i mean, ive been reading that the suction is based on the ECU, and not the material of the pipe and that cold air intakes can cause hydrolock
+1 on the hydro-lock
If you put it in the wrong place and you hit a puddle or in my case your in a flooded car park you will root your engine
http://www.skylinesaustralia.com/forums/St...p;hl=hydro+lock
go to the last few posts to see all the damage, photos and everything.
Be Careful!! - in saying that i put mine in a very stupid spot, it was cold for sure but too exposed to water and to low too the ground - as far as performance, meh i didnt notice much, get someone who has done a dyno run before and after.
IMO, if you put an air pod on, you will be sucking in hot air, unless you shield it off / box it off.
I would just upgrade the panel filter in your stock air box to a high flow K&N one.
At least most of the time, cold air will be going in.
Short answer: yes, properly setup cold air intakes do give you performance gains.
Note that it is not a cold air intake simply because the kit says so or because you installed it / want it to be a cold air intake. It's a cold air intake if the intake temperature has actually decreased from what it was before, due to whatever you did to the intake.
A $300 K&N kit will do buggerall if it's still sucking in hot air from the engine bay - can actually be detrimental to performance / stall your engine in traffic on hot days. In contrast $20 worth of ducting and a properly positioned $50 filter setup the right way can do wonders.
If you're going for a pod style setup, heat shield it and have a ram pipe/ducting running up to it from a cool air source...rather than the filter located close to the ground/rain/water, where it can hydrolock as previously mentioned.
I was looking into these two things a while ago for if i make a cai. Im not sure how effective they are, I thought they would be really popular if they worked as claimed and didnt restrict the flow to much.
Bypass
http://www.modified.com/tech/0104scc_aem_a...alve/index.html
hydrashield filter
http://www.autoanything.com/air-filters/65A2582A0A0.aspx
Edited by Mendoza
also it should be said that the gains aren't that great. people go on about it being some massive performance mod and if they go up against a car without it they are going to leave it for dead. this is far from the truth. the fact that most cars these days come with some form of intake designed to suck air from a location that alloys cool air, in most cases a CAI setup will net you a gain of maybe 5kw in an extreme case, but more than likely only 1 or 2kw. where people often are misled is thay they will put a new highflow panel filter in at the same time as doing the CAI setup and think that all the gains were from the CAI.
as for the power loss from hot air, that is also made to be a bigger deal than it is. when i took my magna to the drags, my quickest ET and top speed was achieved with the snorkel to the airbox removed and it was sucking air from the engine bay. often people go a bit overboard trying to make a CAI and end up with no gain or even a loss because because they have added so much restriction that they have negated any gains from having a cooler intake air.
cara are you saying you got the tune done and the CAI, or just the CAI? cause if the tune was done at the same time then that probably has more to do with it than the CAI.
i used to have a magazine where they fitted a CAI and k&n panel filter to a car and did before and after dyno runs. don't remember too much about the article but i remember the key figure. on a car making around 125rwkw i think it was, the difference in max power with both the CAI and filter was 4kw of the stock snorkel and paper filter.
re done the piping for air intake, and had to get a tune done again cause she was running heaps rich with the new piping......
but comparing the old piping to the new one, the car has a lot more resposiveness that what it did, it wouldnt have changed anything kW was, but at least i got the resposiveness ;)
ive got mine coming from the front of the bar going up to a pod, but what has made the main difference is the piping from the pod to the throttle body.
So you are saying that the silicon piping was the key difference maker? if so, what makes you think so?
Btw, you got more photos of your car - that's very nice looking car, love the paint scheme - not sure about asian-eye headlights tho ;-)
cheers
  • 8 months later...
but comparing the old piping to the new one, the car has a lot more resposiveness that what it did, it wouldnt have changed anything kW was, but at least i got the resposiveness :P
Hey Cara how did you do your CAI piping i see some silicone and some stainless etc can you give more detail.
now this may sound like a stupid question but what happens to all the tubes goin into the stock intake pipe when you change it are they unimportant or do you need to find a way to connect them back up.
sorry for my ignorance on this topic im still learning :-)
Cheers
In my opinion,
gains are so minimal its not worth the money.
Save your money and spnd it on something more worth while.
There is very little increase in power or torque.
The only thing you'll gain is a deep growl under throttle.
If thats the only thing your looking for, just add a pod only.
CAI's have very little menefit unless your car is often working hard in hot conditions.
Edited by GTS4WD
ok, im going to go against what others are saying on here about it.
I have a full heatsheild and cai... if you want to do it yourself for about ~$50 each then it might be worth while looking in the tutorial section...
anyway. When I did it, I did notice a difference in torque and power, but very minimal... it did however increase throttle response.
It used to be with an unshielded pod as hot as the rest of the motor at the end of say a 30 minute drive. What I have noticed change the most is, you know when your car has just warmed up on a cold morning and you give it some beans and the throttle is nice and crispy... well you get that pretty much most of the drive...
I can drive the car for an hour, take the heatsheild off, which is just a little warm, and can touch the pod and it is still cold, so yes, it does make a difference.
Hot days are better for the car aswell, it still suffers from the heat, but no where near as bad...
The thing is, my car is turboed so with more power you can feel the difference more then an n/a...
If you were going to have a crack at it yourself for 100 bucks i'd say worth it, but 300, i think is a bit steep for very minimal gains on a ~100kw skyline, I would put the money to some good oil, plugs, etc or go to a workshop that tunes skylines and get them to advance your timing abit for 100 bucks, you'll gain 10kw out of that as oppose to 1-2kw
  • 4 months later...
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
