  • Replies 304
Posted Images
Hey guys count me in!!
I'll do the form and transfer once i get paid again next week.
For the cams licence, whats the best class? last time i had one it was an L2S a few years ago, is that still the go?
Yep, I'd say an L2S is the best option, as an L2NS rules out your chances of doing some track days.
L2S = Speed
L2NS = Non-Speed
Paid and such..
We dont have to print out our oun scruitineering sheets this time??
Also wont have membership card as it says is needed for signon cause I havnt gotten anything since joining just before last texi..
Cant wait!!
Finally I've had approval to run Mel's Skyline,,,now to get it ready.
1/ Stole wheels off Duncan with rubbish semi's fitted
2/ Get off my arse and fit nismo locker diff
3/ Buy a bloody race seat cheap
4/ Make bracket for firey thingy.
Neil.
Ok, just gotta recheck engagement party times for the day before. Assuming no hassles with the ex, I wanna be there. So it's 45 for the day, how much is the cams license etc? Just checking how much I'll need all up, plus gotta get an extinguisher sigh.
CAMS L2S licence costs around $100 and last 12 months and is valid at most tracks/events as far as I know. You CAN get a L2NS for around $50, but then you are limited to drifting and events like Texi :ninja:
Fire extinguisher you can get from Autobarn or similar for around $30 - $40.
looks like ill be religated to helping out. Pm me SteveO and let me know what i can do, i dont mind marshalling or cooking...whatever.
Good man, get that clutch in.
Meet at mine on the day, we'll drive up together
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
