The turbo will not spool later, as more air is getting sucked in, meaning more air is sent through the exhaust manifold which means it would be travelling at a slightly increased velocity and past the exhaust wheel of the turbo, please explain to me how this will cause extra lag? Also please note that in my original post I specifically noted that the turbo spooled 200rpm earlier. This is from experience and not theory.
Just thinking aloud - the speed of the air would be higher through a more narrow opening than through a larger one. If the overall pressure is reduced, then even though there is more air, it may well be flowing slower.
Of course, if the pressure is the same as before, then the air will be faster (ie. more air, same pressure = higher velocity)...but the point being made is that the turbo will spool later - which _could_ happen if there is less overall pressure due to the increased volume in the plenum. Does that make sense?
However.....IF this extra volume in the plenum helps the engine to breathe better etc, you may well find it revs FASTER, therefore getting onto boost SOONER albeit just higher in the revs...
Just throwing some ideas around - I'm sure you've already done the same while you were thinking about it :)
  • 1 month later...
Fitted my "IAMHE77" M35 spacer special today.
The process is very simple and and requires a bit of dissembling of the motor but should be about a 3 hour job for those not sure what they are doing and if you are really good with a spanner, about 2 1/2 hours.
Net result is that the car definitely feels like it has more torque and on my car with the stock turbo felt a little stronger towards 6000 rpm.
I am not sure about fuel economy improvements.
It is hold each gear much longer without kicking down which is a big improvement.
Thanks Cam
Andy
Nice results Cam, I may be interested...
May I ask what price they are selling for?
Have you looked into making them from insulating material yet?
Oh, I see... so Andy's word has more cred than mine, eh Buddy? :)
Full kit (including OEM gasket, spacer, bolts, bracket extensions) is $300.
No, I have not looked into it yet.
Edited by iamhe77
  • 1 month later...
Okay, so after a fair while of running the aluminium spacers (and enjoying the benefits!) there will be kits with the spacers made from Phenolic which will eliminate the heat soak that the aluminium unit suffered from.
This will lower intake temps, which should provide a power and torque increase instead of just the torque increase of the original.
As for pricing/timing/pics etc.... I am sure Andy will fill you in as he is the catalyst behind the change :)
Edited by iamhe77
very nice work guys!
whats phenolic again?? some sort of plastic??
it refers to material that is a composite of resin and almost any other material and is set with heat and pressure.
Makes it very durable and extremely heat resistant.
we should be able to post up pricing next week.
Cheers
Andy
Close, but no cigar.
You have to think in terms of an NA vehicle, when you are this close to the cylinder. Air speed is king at this point, so a longer inlet tract allows the inllet charge to speed up at lower revs, allowing better cylinder filling, which allows much cleaner combustion, and ergo, more torque generated at low revs.
The offset of this, is as revs increase (and by default, airspeed) the advantage of a longer inlet tract becomes less of an advantage due to the pressure differential caused by the bottlenecks in the short turn radius, valve stem guides and even the valve throat itself. There is a certain RPM threshold for any motor when then length of the inlet tract and the extra air speed it generates become a liability. This is why manufacturers have played with variable length inlet tracts for years now (first one I know of is the EL-EF "snail shell" inlet manifold) -*warning - physics alert* because according to Charles Law, with excessive air speed, the added pressure generated at this point will lead to an increase in the temperature of the inlet charge.
Its for this reason that a phenolic spacer would make the most sense, by not retaining any of this extra heat being generated, although carby spacers were traditionally made from this material more for their ability to isolate the carb from vibration (which allows for much better fuel atomisation), as well as increasing inlet tract length,
As for the increased volume of the plenum, this would be a neglible percentage, and if it did affect the level of RPM that boost was acheived, it would be so tiny as to be uncalculable (we are talking microseconds here) Keep in mind that the boost limit is set by the efficiency of the turbo and its ability to provide a given level of boost at a given RPM. Its only when you put something with the volume of, say, a FMIC within the inlet tract would you notice any difference.
Cheers for that Dale :(
Well, I have been running around today with one if the phenolic spacers on my car and I can tell you that they are better than the aluminium one.
Car seems more "solid" and "together" than with the aluminium spacer, particularly in the lower rev range and after a rather spirited drive to work (winding hills, round abouts, 100kph zones) I could rest my hand comfortably on the plenum... which, if any of you have tried on a stock car is virtually impossible without getting burned.
Definitely recommended.... for any type of driving. :P
Edited by iamhe77
are you guys worried about the phenolic material cracking or breaking under the pressure of being compressed by the plenum studs/bolt? i work on some equipment the uses phenolic material, and as hard and heat resistant as it is, i have found that after some time in use it can become quite brittle and pieces chip away or even crack through.
No not worried about it cracking or breaking under pressure. What type of application are you using it with? What type of Phenolic are you using....canvas? Heat rating?
Not being a smart arse either...just interested.....we've done a fair bit of research into the type we have used but we also welcome any further info that people might have.
Edited by Jetwreck
Not being a smart arse either...just interested.....we've done a fair bit of research into the type we have used.
I dont know the exact composition but it is some kind of material/canvas and resin mix. heat rating up in the 250-300 deg C range. Used for components in large industrial ovens. Granted they are constantly used in temps above 200c the better part of each day, which would be more extreme than an engine bay. But have found that if i'm not careful during installation it will damage easily. The most frequent failure i see is with phenolic wheels, sometimes only lasting a couple months before they fall to bits.
I may be familiar with a different grade of phenolic than what your using though, i don't know. I knew you guys would have looked into it, i was just interested in your thoughts/findings, as the phenolic i'm familiar with i would not be comfortable using anywhere on my engine.
Edited by QWK32
Yeh our application is a little different....our temps will only probably ever get up to about 5C-30C on non traffic roads and 60-70C in traffic....the heat range of the 16mm thick canvas product we are using is good for 250-300 deg C and its a non moving part.
The Spacer has all been pretty much match ported to the intake manifold with a CAD drawing.
P.S. Correct me if I am wrong Andy/Cam
may be just get up to 80c but I would not think more.
  • 4 weeks later...
So we installed another of these phenolic runner spacers on my mates stock M35, unfortunately he does not frequent this forum but this is what he had to say (cut and pasted from an email in which I asked him what difference, if any, he has noticed with the addition of the spacer).
Went to the airport and back last week, then to Leongatha (waved to your house on the way past) on good friday and up to Corowa (NSW border) for the weekend....
10.4 l/100km.. That is the lowest I have ever had, even lower than when I collected the car and drove back from Sydney like a wuss, because I had no numberplates..
688 kms range... Could easily have done over 700 as refuel was only 72 litres...
As stated, car holds 5th gear much better and there is off boost performance.. Very happy thanks!! And engine cover is happily fitted with just the rear nuts holding it on..
will try to get some longer studs for the front sorted out.
Thanks again.
So it seems that the recurring theme from this mod is greater off-boost performance, more torque and the car holds 5th much better while cruising
If interested, please either post in this thread or PM either Andy65b or Jetwreck.
Edited by iamhe77
I did but I changed injectors at the same time. Gained 16kw. I wish I had done one mod at a time but I needed the spacer due to the longer injectors.
The idea is to increase the speed of the airflow into the cylinder, especially in the midrange, filling it quicker, right? Smaller ports will help with this as well as longer runners. It just goes against popular belief unfortunately.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
