New Noob Likes Her New Car
Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done. -
You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
